Oil Filter vibrating loose!?!
Yzcr87
The idea of a filter loosening itself sounds ridiculous but I've noticed the same on my 23'. The OEM filter was tightened with the force of a thousand suns. The next 5 oil changes I thought I was losing my mind when noticing how loose the filter was on removal each time. No leaks, just not "hand tight".
I'm due for my 6th oil change tonight & I'm gonna mark the filters position on the housing to see if it actually is somehow loosening itself or if I need to book myself a reservation for the funny farm.
WIX 57060 & M1 EP 0w-20 at 5,000mi intervals for reference.
SD Rebel
San Diego, CA
I've never had this issue with the OEM Mopar filter. I tighter 1 full turn after initial contact as per instructions (about as tight as a hand can do with normal strength) and never had anything close to a loose oil filter even a year later or 5,000 miles.
Fwiw, the rubber gasket will compress some with heat cycles. So filter may not be turning to loosen, just the gasket compressing some
Mike_WI
Make sure your oil pressure sensor isn't loose and leaking. I kept thinking my filters were getting loose and leaking oil. But 1000 miles I to my last oil change I actually saw drops of oil under the truck. First time since I've had it. Since my truck is lifted I can craw under it without jacking it up. Crawler under and filter was snug. Did some quick google searching which pointed me to pressure sensor. Reached down and I could turn the sensor by hand. I tightened it up. Haven't seen.any oil drops since. Need to look and see if the filter is coated like it was doing before, when I thought my filter was coming loose
That's a new path to explore. I will definitely look into that. Not exactly sure where the oil pressure sensor resides, but I'll figure it out. Thanks for the reply.
Mike_WI
Just a bad dealership. I use the SRT filters with no problems. You can also use a regular strap oil filter to tighten it and then to lose it. Factory filter I had to use oil wrench pliers to get it off destroying the filter in the process.
All other cars/trucks I use K&N due to the nut but I wasn't happy with how small the filter was that matched the truck.
I've never had to use a wrench to further tighten a filter, but I'm not against it in this case. I've never really cared for the metal band oil filter wrenches. I'll probably use a rubber banded strap wrench. Up to this point, my favorite oil filter wrench to only remove filters has been this cheap set I bought from Harbor Freight of all places. Kind of like a uniquely shaped slip joint set of pliers, with 2 opposing, crescent moon shaped jaws. They've been great honestly. I wouldn't want to use them to tighten though, as they will most likely pinch and deform the filter a bit, or worse.
Dewey
WI
Same here. 3/4-1 turn and never had a problem. I need to use my strap wrench to loosen every single time and I even go closer to 10,000 miles between changes.
It's directly above the oil filter. Just checked mine and it's bone dry now. Before my filter would have a thin costing of oil all over it.
