I have attached several diagrams. At first glance, they are confusing but hopefully I can help make sense of them. First, lets focus on the big yellow connectors under the driver's and passenger's seats. The passenger seat is where the wires from the power distribution system and CAN IHS system connect. That big yellow plug under the passenger seat is XY420A on the diagram. The wires in plug position numbers 5, 1, 14, 15, 30, 6, 7, 9, 4, and 8 on the body side of the plug pass through the seat side of the plug to the heated seat / wheel module, which is mounted under the passenger seat. (Don't worry about the seat side of the plug. Those wires will be included in the seat wiring harness you will need to order if you don't already have the module and heat pads. If you get seats from a wrecked truck that had heated seats, it will have them. That is probably the easiest and cheapest solution. Otherwise, you will need 2 seat heat pads, 2 back heat pads, driver's seat wire harness, passenger seat wire harness, and the heated seat control module. Individually, the parts aren't too expensive but combined, it gets really expensive.) The wires in positions 5 and 1 are from the power distribution center, which is located above the passenger side kick panel. The wires in positions 14 and 15 are from the CAN IHS connector, which is above the driver's side kick panel. The wires in positions 6,7,9,4, and 8 come from the body side of the big yellow connector under the driver's seat. That plug is XY410A on the diagram. I have included the pin-out diagram / list for both plugs. The first step is to investigate your plugs to see if you have wires in those positions. If not, you will need to fabricate a wire harness to add them. I believe it is a total of 12 wires. I have not made my wire harness yet but am confident I can. Depending on your DIY skill level and risk tolerance, you may want to stop here. We haven't even gotten to the center stack, steering wheel, and OBDScan programming yet. This is not for the faint of heart.
