Rocker Panel nuts
teedup324
I bought running boards for my 2023 1500 and the nuts that came with them (5/16") will thread on the top bolt but not on the bottom ones. It doesn't look like there is overspray and I tried a steel brush but it didn't help and I'm afraid to force them on and strip something out. See pic below and you can see the diff in the bolts. I have a tap and die but I don't think the thread count is correct b/c the 5/16" won't fit. It seems to be a 20 but I'm not sure. I think the bolts are M8-1.25. Anyone run into this before? Any suggestions?
Looks like paint, most wire brushes aren't strong enough to strip them by hand, the die works great, below is the link of the one you need. Make sure to thread it by hand first, once it's straight, use socket wrench to screw down all the way and then remove. Once you do that, those OEM board nuts will screw on with a finger. Once you clean the threads and screw on the running board, the torque setting is 15 lbs-ft, use some blue thread locker as well.
The die needed is 8-1 25mm, here is the once I purchased just for this task: https://www.amazon.com/gp/product/B0015UXIOE/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Edit - Notice you may have two different bolt patterns on your truck? Not sure, mine were the same top and bottom, please double check before you try to screw them on.
Had the same problem when I put on running boards. It is just a protective finish on the bolts to keep then from rusting. Don't retap then as you will remove the protection. Just use a bigger wrench and tighten then down.
You could risk over torqueing them if you do that, the torque spec is only 15 lbs-ft. Most installation instructions recommend cleaning the threads for that reason.
The die is the best method as it only cleans off the excess paint. Mine have been like that for 4 years, zero rust when I removed them recently.
And how would I do that?
I looked at your pic more closely, they seem to be similar to mine on my 2019. I suspect the reason why your nuts don't fit on the lower bolts is there is just too much paint on them.
I would buy the die link I posted and try to clean them up, those nuts should screw on properly then, unless they aren't OEM?
You have a picture of the nuts you are using?
My own experience was a little wire wheel worked best for the paint removal. Some of the studs had an inordinate amount of paint and the thread chaser was not doing it's job.
Grinder + wire wheel… don’t be a caveman.. use power tools.
Those don't look like the nuts that came with my running board, they were flanged out on one end. Before you do anything, make sure you have the correct thread nuts. As you mentioned, I believe M8x1.25. You will still need to clean the threads even with the correct ones.
Check out this ad for OEM running boards, on the bottom pic is what my hardware looked like: https://www.amazon.com/Mopar-2019-2020-Matte-Running-Boards/dp/B082VHYS4F
Thanks for all the replies, I got them installed.
View attachment 175154View attachment 175152
Looks good brother! Are those the Go Rhino RB10’s? Slim or Regular? If they are, are they adjustable at all? I like the look of them but hate the gap between the step and pinch weld. I’m looking for something that hugs tight. Do you have any pics of how tight they are to the pinch weld? Thanks in advance!
