USB hub
Laramie2022!
Plugged a charging cable into an iPhone and sitting two minutes an error message showed up on the screen. “Power surge on USB hub detected. “. The one cable was the only thing plugged into the truck systems. Was not able to change screens to get the error message to go away. Turned the truck off and on, the error message was still showing. Any idea what the cause of error message is?
In computers, it is usually a bad cable.
Guys - any one towing with a drive-tran disconnect installed on a 2 wheel drive Ram, 2019, Laramie, with push button starting? My concern is. I have to turn the rear collision system off when the truck is towing a trailer and I am backing up, the truck thinks I am too close to the trailer and auto slams on brakes. Is there anything needing to be done to disconnect electronically to kill the Auto Breaking systems, ie, Anti-Collision systems for front and/or rear collision systems when the RAM is being towed? Thanks
I have the same issue and got brand new iPhone cable and still have issues ?
Probably need to replace the usb hub
It can be adjusted in settings.
