TheDoho
I started noticing issues on the 2nd. I started the remote start to heat up the truck at night and it was warm but not as hot as it should be for sitting 8-10 minutes. There was frost on the inside of the window that would not dissipate despite the heat being on the entire 15 minute ride home. The heat was warm to lukewarm and would not properly heat the inside of the vehicle. On the 3rd I noticed that there was still frost on the inside of my windshield (and the windshield only) after sitting all night. The heating issue was more prevalent, even blowing cold air for the first 10 minutes of the truck being on. I had it on max temperature and max speed while driving around. It finally warmed up but it was lukewarm at best and anything below a 4 out of 7 speed would make the windows fog up. On the 4th there was still frost on the inside of my windshield but when I started the truck and drove for a couple minutes at max heat and temperature the truck seemed to heat up in just a couple of minutes and started to dissipate the frost and fog. I parked the truck while at work and that evening I came out and discovered more frost on the windshield with most of it on the passenger side. I started the truck (not remote started) and it seemed to heat up fine as it did before work.
I can’t get in until the 15th. Anyone have any issues or potential remedies until then? IMG_3740.jpeg
Check to see if the condensate drain is clogged not allowing water to drain. Check your coolant level. If it's low it could cause intermittent issues.
c3k
What was your coolant temperature when this was happening?
Oil temp?
TheDoho
Sure enough the coolant is low. Any recommendations on coolant brand? I’m not sure if I have access to Mopar brand
Jako
Borough of Parks
I do not have a good answer for "any recommendation on coolant brand" as I could not find one myself. Be careful as far as putting in the correct coolant. More info below in the the thread.
FYI
"FROM EXPERIENCE (first time):
Forget the MS.90032. This seems to be a Mopar secret. It fits in the same category as the torque setting for the oil drain plug and the number for the Mopar oil filter.
The Ram will take MS-12106, it is available pre mixed or as a concentrate.
I added 8 ozs. at a time for a total of 24 ozs. of coolant which raised the level approximately 2 3/4".
For the antifreeze dipstick this works out as following.
The holes are very close to 1 1/8" apart and equates to 9.82 ozs. from hole to hole.
The first picture is towards the bottom of the dipstick and the 2 black marks represent the initial level and after adding 8 ozs. I used medical tape on the dipstick to get an exact reading on the dipstick. If you look through the tape you can see the minimum mark hole and the one above it."
TheDoho
Thanks everyone. I went to my local dodge dealership and ended up buying the pre-diluted coolant. The heat has been fine since yesterday and seems to be fine so far. I’ll update if I have any other issues
Jako
Borough of Parks
How much did you have to add?
c3k
Glad the heating issue is resolved...BUT...
The bigger issue is what caused the coolant to get low?
TheDoho
It was at or below MIN and I filled it to MAX. Maybe 1/3-1/2 the bottle of Mopar coolant
That’s what worries me too. The frost on the inside doesn’t seem to be an issue anymore but I’m letting it sit for 8 hours at work tonight so we’ll see. I did take it through a drive through car wash around the time the frost popped up and I haven’t been to one of those in years. Maybe water leaked in from there?
BowDown
Frisco TX
Check your oil dipstick
If it was still showing on the dipstick, then coolant level wasnt your issue.
TheDoho
What’re you thinking?
The coolant was on the bottom 2/3 of the dipstick. I put the coolant in after driving around in the truck for a little bit. I’m going to check it again tonight after it’s been sitting for a couple hours.
BowDown
Frisco TX
See if your oil is milky, if so, that's where the coolant went
U
User_3336
Guest
Straight from the Mopar Chemicals Catalog. The dark color circle represents PURPLE.
TheDoho
So I’m almost half way through my shift. No frost on the inside of my windshield, oil appears normal for having 65% life and I’m not seeing any puddles underneath or leaks underneath. It’s hard to get pics at night but I will get pics in the morning
bsn0912
I just talked to a buddy yesterday, who was a service tech for CDJR, cause I’m having the same heating issue. He said this is common with the 5th Gen Rams, and they leak coolant from pretty much anywhere that coolant can leak from.
Dragonmaster13
Mine was doing what you described, found a leak in the heater core (sweet coolant smell on the inside of the truck when heat was on), and also found a sweating leak at the front of the engine on the upper driver side from one of the cheap plastic elbows coming out of the front of the block.
