Logantryan
- Apr 27, 2023
2021 Ram limited passenger accent strip some days stays on all day like it is suppose to. Other days it’ll come on then a second later turn off. Only times I’ve noticed it comes on but turns off is when I remote start (either the top or bottom strip will light up first then turn off) / using a turn signal during the day (the strip turns off - turn signal comes on and the strip won’t turn on again) / or using the manual knob near the steering wheel (when turned off then switched to auto it lights up then turns off). It’s very hit or miss everyday on if it stays on or not. Just this morning it stayed on during my 30 minute trip. Then later in the day I noticed it was out again.
I have no lights on the dash either. First dealer appointment they said they couldn’t replicate the issue but they called me 5 mins before close so I assume they didn’t try. Finally got a hold of them a few days later. Sent someone a photo and video showing the problem and was told I would need a new bulb. Quoted me 1400 for the part and 1823 after labor and taxes. At that point I’d rather just buy a TazerDT and turn the amber DRL on with that being a cheaper route. Seems odd how the light does come up. Just doesn’t stay on. Wasn’t sure if there was another solution to the problem.
Attached is an example photo.
