I’m not concerned just more so wondering if it’s common. I usually turn auto start off anyway.Mine is not always 100% smooth but it's not enough that I have been concerned. I've not noticed any kind of stalling at start up. It often seems more ready to race away from a stop sign than I am.
One of the purposes of the eTorque is to prevent delays in movement while waiting for the vehicle to fire during autostart. It is supposed to spin the crankshift to restart the truck while at the same time providing up to 90 lbs of torque for forward momentum. This source says it "resumes forward motion within 70 milliseconds after an auto-stop".
70 millisecondsMine is not always 100% smooth but it's not enough that I have been concerned. I've not noticed any kind of stalling at start up. It often seems more ready to race away from a stop sign than I am.
70 milliseconds
They better recalibrate that stopwatch
Mine is more like one second. The delay is very noticeable. So much that I keep A/S disabled.
You won't get used to it. I had a 21 and now a 22, still don't like the pause/jumpy throttle from a dead stop. What I do like is I have no problem getting the heavier tires to start rolling.I find my extremely jumpy... When the truck auto stops, I always just take my foot off the brake, pause a sec and then step on the gas. If I don't, it lays you back in the seat and tries to give you whiplash. I'm assuming I'm just not used to it yet, since I've only had it a couple weeks.
Mine shuts off while I'm still rolling forward. Mind you I'm only doing like 1km or 2km an hour, but I am definitely still rolling when the engine shuts off.Mine Auto Start/Stop works smooth as glass. The engine turns off about 1.5 seconds after I come to a complete stop and turns on immediately after releasing the brake, I step on the gas pedal and drive off, as if it was never shut down.
Are some of you having issues two-foot drivers, and maybe stepping on gas pedal before releasing brake completely?
Had to edit, it didn't like that had A SS instead of Auto Start/Stop
 . I slowly learned to live with it and now actually like it other than the regen braking.
. I slowly learned to live with it and now actually like it other than the regen braking.There is a learning curve here for sure. Mines very new and the auto start is immediate after releasing the brake, sometimes totally unnoticeable. If i give it a second and go easy on the gas pedal i can be ultra smooth, but i carelessly hit the gas once and it accelerated like a demon - BANG, we are off !!I find my extremely jumpy... When the truck auto stops, I always just take my foot off the brake, pause a sec and then step on the gas. If I don't, it lays you back in the seat and tries to give you whiplash. I'm assuming I'm just not used to it yet, since I've only had it a couple weeks.
I wonder if it's the regen braking that I'm noticing. Does it still activate even if you are just inching forward or when you are in reverse? Can you turn it off? I'd like to be able to do some testing with it on and off...I have no problems with acceleration other than a bit of throttle lag. My problem is the stupid regenerative braking! When I first bought my truck in '20 I HATED A/S/S. I slowly learned to live with it and now actually like it other than the regen braking.
Mine kicks in when slowing down from speed like at a stoplight. I have to very lightly "feather" the brake pedal to come to a smooth stop. The best way i can explain how it feels is like the brakes are catching or the transmission is downshifting.I wonder if it's the regen braking that I'm noticing. Does it still activate even if you are just inching forward or when you are in reverse? Can you turn it off? I'd like to be able to do some testing with it on and off...
Nope can't turn it off. Even if your disable all of the eTorque features that would drain the battery it always regensI wonder if it's the regen braking that I'm noticing. Does it still activate even if you are just inching forward or when you are in reverse? Can you turn it off? I'd like to be able to do some testing with it on and off...
If I'm stopped and the engine is off as soon as I shift out of drive, to neutral to get to reverse the engine starts, so mine doesn't work in reverse.I wonder if it's the regen braking that I'm noticing. Does it still activate even if you are just inching forward or when you are in reverse? Can you turn it off? I'd like to be able to do some testing with it on and off...
I was speaking of the regen braking in reverse if you are feathering the brake. Just seems really jerky and is hard to modulate if you are trying to reverse (or go forwards) slowly and in small amounts.If I'm stopped and the engine is off as soon as I shift out of drive, to neutral to get to reverse the engine starts, so mine doesn't work in reverse.
