TurdFerguson
- Sep 19, 2018
Sunofagun... ya beat me!Trim around cup holder pops up and then there are two Phillips screws to unscrew then it pops off
Only because Ive done it before. Added Headrest DVD players rot mine and mounted the box there.Sunofagun... ya beat me!
I dont have a thread but I can post a pic.Pictures? Do you have a thread on this? I’m curious with my two young boys....
Is there anything in there to tap into for 12v? or am I coming from somewhere else?I dont have a thread but I can post a pic.
Yes I think it was pink and yellowIs there anything in there to tap into for 12v? or am I coming from somewhere else?
You rule. Was it always on power? or ACC?Yes I think it was pink and yellow
Thanks, AccYou rule. Was it always on power? or ACC?
They both have DVD players. Touchscreens and android for apps. That part sucks though as it runs an old version and most new apps aren't compatible. So I installed an Apple TV and all my movies are through that anyways. So we can watch netflix or directs now while on a trip. Its awesome. Didn't mean to highjack the thread.
View attachment 13056View attachment 13057View attachment 13058View attachment 13055View attachment 13056View attachment 13057View attachment 13058
Don’t mean to keep hijacking but I really like those headrests and the idea of an AppleTV in the back. I went to the Advent Site to price but couldn’t click on the link from my phone to email them. Care to share how much those run? And do they both use the same source or can you have two different sources, one for each headrest? TIA
I believe they are 1500$ or so new. They are configurable. You can get them as DVD in each headrest or DVD in each headrest with the android touchscreen. Honestly I dont suggest the android because they RUN KitKat and doest support newer apps. So I went the route of the Apple TV because I have one in every room of the house and all of our movies are in iTunes. So as its set up we can watch a dvd in each headrest independent or they can watch the same dvd together or they can watch one with Apple TV and the other with DVD. They come with IR Headphones. Advent owns Invision so the quality of material is OEM. Invision is who manufactured all DVD headrest for Ford and GM like what comes in the Platinum Escalades.
The Apple TV is 120 volt so you can use the inverter if you have on but what I did is convert the internal supply of the Apple TV to a 12volt supply. These can be found on ebay for about $60. Its not that difficult to do and they are a direct install no mods to the Apple TV its awesome and I have not had one single problem with it I have two set up this way. Plus the remote is bluetooth so you can mount the Apple TV anywhere.
The headrest do not have an HDMI input at the control box so I had to buy a HDMI to rca cable. I found on on Amazon and it works incredibly. Its powered with a USB a cable. I also bought a USB power supply and wired it in so this would all be hidden.
Its really awesome. I use either the built in wifi hotspot of the truck or if I am in an area At&T is not available I switch to my Verizon hotspot in my console. Between them I have been covered going to anywhere I have been. If you aren't then you have DVD as a failsafe.
Power supply kit Apple TV 4th gen - https://www.ebay.com/itm/PA-1110-7A...h=item5459bf66c8:g:F4UAAOSw~qxavfUd:rk:2:pf:0
HDMI to RCA - https://www.amazon.com/Converter-Ad...82862&sr=8-2-spons&keywords=hdmi+to+RCA&psc=1
USB power adapter - https://www.amazon.com/HOMREE-Conve...qid=1546982930&sr=8-3&keywords=12+volt+to+USB
Truth.Thank you for the detailed info. I really like this setup and it’s very clean but I guess it seems hard for me to justify at that price. At $1500+ I could buy 5 iPads and store them in the center console.
It is true. What also is true is they have to hold them and charge them and have data plans on each one and if you have three kids Like I do they have phones also. We just went on a26 hour trip for Christmas and that is a long trip for holding iPads. Also a data access for unlimited data a month per person. And then in areas of no cell coverage. The list goes on. So you can nickel and dime yourself on cell data plans at 20 - 30 a month x 5 and even if you buy wifi iPads with no data plan and then use the truck hot spot 5 iPads will eat up 22GB in a heartbeat and after the high speed allotment is gone its unusable.
With my hotspots I have the Att stream saver that doesn't count towards my data allotment and same with Verizon.
I have one device using data and that is the Apple TV. The kids each have a phone that can also airplay to the Apple TV in a pinch incase we were by some reason to go over our data on the hotspot. My kids will have phones as its a necessity for them. iPads are not.
One other thing is these headrest can be moved to a new vehicle. you just have to buy new headrest buns that are about $150-$200. So if you use them for a few years and buy a new truck the electronics transfer. Ive never had a vehicle without them.
