285/55R22 Nitto Ridge Grapplers on stock no-lift Ram / Heatgun'd for tirerubs
Looking to add the 285/55/22's to my 2021 1500 Limited Have the air suspension and do not want to lift or level. But also don't want the rub. Does the heat gun method work? How difficult is this to do?
The tires are amazingly quiet. I thought there would be more Road Noise, but not a lot so far. There was only two spots on the flimsy plastic. I used a heat gun on the front and back inside plastic and no more rub. Very happy so far.
Took a leap and went with 33x12.5R22 AT’s on stock 22”s yesterday, will need to zip tie inner mud flaps. Cleared the UCA by about 1/4”
What pressure is every one running in there LT E rated tires?
I just installed Toyo AT 3’s in LT285/60/20 and can’t seem to decide on what pressure I like.
Best would be to google "Chalk test" or contact manufacturer with vehicle and tire information.
How have those 33s been for you? I’m getting tires this week and want to know before I pull the trigger.
I got rid of the weenie SUV tires for some 285/55R22 Recon Grapplers, and love them! I had a 3/1.5 lift/level kit installed, and everything is perfect, aside from a slight rub on the front passenger side when the wheels are cranked to the left.
Sorry I don't have better pics
Before:
After:
My buddy's Big Horn has the same lift/level kit with some 35x11.50R18s. Both trucks sit the same height.
