Theme resetting solution?
Cbeach1122
I recently bought a 19 Laramie and when I set the theme the instrument cluster keeps resetting. Did they ever come up with some sort of fix or a solution to this issue? When I checked for a uconnect update with my VIN it says my version is up to date.
You can't tell if your uconnect is up to date with the website. It always says it is up to date no matter what.
Look around in here and compair your version to what people are finding.
You have UC4 for reference
What display do you have? If you don't have the Nav display, the theme won't stay.
I do have the navigation display. Usually the display on my instrument cluster will stay a few hours or so. Then it switches back to the original display
I have the same issue with my 2019 Laramie, it is frustrating.
I have a 2019 Laramie as well. I cant find any option in the U connect to change the theme. Am I missing something here?
It should be available in settings>Display>set themes. I have the Alpine 12.0.
I’ve had my display on Longhorn Brown and it has only reset to Bighorn red whenever I remove the battery.
I’m thinking I am going to get a Tazer DM which I have heard will allow me to program the splash info display. I also like a lot of the other settings it will allow me to program.
