www.instagram.com
				Someone has been watching too much Pxxxhub... lol
That’s because Coed assumes there are only two genders and they don’t want to offend .000035% of the population.I haven't seen a "Coed Naked" tee shirt in 20 years! View attachment 171586
If gender is a spectrum, then why is there only two options for a sex change operations?
Good point. Can you tell this to msnbc?If gender is a spectrum, then why is there only two options for a sex change operations?
I’ve tried calling into multiple shows on MSNBC and CNN, but I always fail their prescreening test. I think it’s designed to eliminate people with common sense.Good point. Can you tell this to msnbc?
I've been told engines run the best just before they blow up. So ... this must have been epic!
There are at least three.If gender is a spectrum, then why is there only two options for a sex change operations?
Sounds good in theory, but all they’ve created is a man/woman with no genitalia. No amount or surgery will change a persons gender.There are at least three.
A less common but more symbolically apt surgery performed by Peters and his colleagues is known as “nullification,” in which a smooth, continuous skin covering from the abdomen to the groin is created following a castration or vaginectomy. In other words, the genitalia are replaced by nothing. Nullification surgery is the perfect symbol for the ideology behind the trans movement: the pursuit of the Latin nullum, meaning “nothing”; or the related nihil, the root of the English word “nihilism.” Trans ideology is animated by a profound nihilism that denies human nature and enables barbarism in the name of progress.
Inside the Transgender Empire
