2 problems in 2 days
SFDucky
2019 Ram 1500 w/ 5.7 Hemi...
1st problem: touch screen, upon start-up, came on white with vertical-colored lines and stayed that way for about 30 min., then went to complete black. Took it to a mech. shop (early am) to see if their OBD2 reader would tell me/us anything - nothing. Had errands to run... eventually the screen came back to life (end of day), first faint, then gradually more pronounced until fully intact & functional. What to do, if anything?
Next day, (problem #2) the Check Engine light came on... this time I got an error code P01060 (Map Circuit Range/Performance Problem). How serious is this? (I tow a lot, so...) Is this an easy fix? Where is said sensor (or could it be something else)?
Bonus: The week before, I also got another Check Engine light / error code U111E9 (Radiator Shutter) that also went out on its own... any thoughts on this, as well?
MAP(manifold absolute pressure) sensor. It's on the intake manifold. Not exactly sure where on the Hemi. If it is going bad, yes it can cause issues. Should be fairly easy to swap
maybe the main battery is starting to go bad, or a bad connection? Our truck are very dependent on a good battery source
