2019 Ram 1500 Classic rear diff out
Redwolf1155
So the rear diff in my dad's 2019 ram 1500 classic went out on a fishing trip 300 miles from home and we had to trailer it back.
My question:
Does anyone know why the truck would be unable to move itself in 4x4H or L?
Luckily his truck has a winch on it and we were able to use it to load. However that doesn't help so much with unloading and moving the truck to where we can work on it.
kapinallinen2
5thGenRams Supporter
Southern Maryland.
My question:
With that carnage, the rear ring and pinion is most likely jammed up and not turning.
Try disconnecting the rear drive shaft, should move then.
Cbty2050
Wouldn't that be the same as neutral? If the ring and pinion are jambed from debris good luck until you get it cleaned out.
How many miles on the truck?
kapinallinen2
Southern Maryland.
It would, but if they tried to drive it under its own power, then that could be a no-go with out disconnecting the rear drive shaft.
Disconnecting the rear driveshaft won't work with the transfer case. It will constantly be trying to send power to the rear wheels and will burn up the transfer case.
kapinallinen2
Southern Maryland.
Just to clarify, I am talking about disconnecting the rear drive shaft from the transfer case to the rear differential.
The rear axles are already "disconnected" by the blown spider gears.
I know what you meant. You have to understand how the transfer case works to realize removing the rear driveshaft won't make the truck move under its own power, at least not very well
kapinallinen2
Southern Maryland.
Front wheel drive is better than no wheel drive. Specially if one wants to get the truck off the trailer. YMMW.
Redwolf1155
The rear driveshaft spins freely. It also spun freely before i removed the spider gears which were laying in the bottom of the case. From in case inspection the ring, pinion, & axle gears appear to have no damage.
kapinallinen2
Southern Maryland.
Did someone pull the orange neutral release?
edit: come to think of it, you might have a blown T-case.
Techneck
At this point its probably one of three reasons:
Blown t case, (no power output at all on either front or rear output)
Front diff cv disconnect lockers are not engaging (front drive shaft is spinning when you try to put power down, but the front wheels are not getting power) i always thought these were a bad design... after watching toyota and ford fail misrably with them, dodge decided to give it a go.
Bad 4x4 actuator (unbolt it, use a set of vice grips to turn the stud to 4x4, try again), this one is fairly common on the dodge trucks with the electronic shift of the fly. And you dont know its dead till you need to use it lol
