I have a 2022 RAM 1500 Big Horn eTorque Sport. I was trying to install a Garmin Dashcam 47. What a nightmare! There is no documentation on the USB ports in the Owner's manual. Simply by playing I found out that they are on 24/7. There is a cigarette lighter on the dash but found out it is on 24/7 too. So what brainiac at RAM decided not to put any ports in that follow the state of the ignition?
To continue..... Garmin makes a device that plugs into the OBD that turn the power off to its onboard USB ports in 10 minutes. RAM counters by putting in a non-standard OBD port. Is there no end to RAM's stupidity?
I hate to sound a little down on RAM but damn.... how much thought did they put in to the power situation? Anything plugged into any of the supplied USB ports will eventually drain the battery. Nicely done RAM! What a total bunch of morons! I can't be the only one encountering this problem. How have others over come it?
