TurboRabbit
- Oct 17, 2023
Unfortunately the truck I bought did not come with the bed utility group. Today I picked up the rails for by bed area for my 2023 Ram 1500. Right off the bat I figured I would have issues installing the inserts due to having this spray in liner, sure enough I did. I got a small file to remove the bed liner material from the polygon opening. After some "Work" I got the inserts in and pulled out my torque wrench out to tighten down to 9Nm as the insert stated. I didn't even get the torque wrench to register as the insert just simply turned in the opening. I did not file that much material off and the inserts took a lot of effort to get them inserted, there were nice and tight. So grabbed a pair of vice grips to hold the insert as it tighten the bolt. It crushed as designed but instead of collapsing behind the sheet metal, it made a larger hole. Just my luck. I'm now thinking the area designed to crush is not in the ideal location (depth) due to the surface area covered with spray on liner that is located on the inside of the bed throwing it off. Looking for suggestion on fastening solutions as I'm to the point now where I don't feel the included ones are going to work for me without removing the liner in small section where these openings are.
