My etorque
Anthony76
Has somebody found a way to turn the system up to like 5mpg gain something more than nothing If l add a battery pack what's the best way they need to be wired and were
vincentw56
Has somebody found a way to turn the system up to 5mpg gain. If l have to add a battery pack what's the best way they need to be wired and were
What are you asking? I am assuming, you are asking if you can get more use of the eTorque by adding an extra battery. You obviously don't know how the eTorque works at all. I'd suggest reading up on it. It doesn't work like you think it does.
Anthony76
The 5.7 is a Remy motor ac Delco, most can be modified from the factory but you could be correct and it may not be able to do anymore. Maybe it's just a pathetic system it is.
Anthony76
The 5.7 is a Remy motor ac Delco, most can be modified from the factory but you could be correct and it may not be able to to anymore. Maybe it's just a pathetic system it is
You’ll have to clarify the question, but I’m sure the answer is no.
Is there anyway to turn the etorque system up meaning be more powerful. I would be hooking it up to the jeep 4xe battery or Pacificas main big battery
Biga
Cincinnati
If it was an easy upgrade to get 5 more MPG out of Etorque Ram would have done it, they would be way ahead of every other manufacturer in MPG if that was the case.
theblet
Nerp
