Gabby2019Ram
- Apr 30, 2023
Yes the other side is fineIs that the only area?
I only pressure wash the wheel walls and undercarriage the rest of the truck is hand washed.You using the high pressure car wash often?
That surface under the paint doesn't look properly prepped.
No never been painted or in a accident brought it brand New in 2019.Was that panel ever repaired or painted? Especially right under the headlight, it does look like poor prep or repair.
No never been painted had it since it had 20 miles on it ,no accidents or body damage. It started out small then when we got this tropical storm on Saturday that's what it looked like afterwards.I pressure wash my entire truck everytime I wash it and dont have that. That part was repainted at some point with crap surface prep
It don't feel like it's plastic when I touch it or fiberglass but I'm going to take it by National Dodge on Saturday.Since it is plastic could be too much flex, paint not mixed right for flexing, or any other issue. You can replace it pretty easy and I do believe you can get it already painted from the parts department.
I'm 100% sure its plastic. I had mine off before.It don't feel like it's plastic when I touch it or fiberglass but I'm going to take it by National Dodge on Saturday.
Yes a real hard plastic and you said you took yours off beforeI'm 100% sure its plastic. I had mine off before.
Yes, part of installing the surround view cameras was removing those to remove the grill to install the front camera.Yes a real hard plastic and you said you took yours off before
I think its a little to late for that I would need alot of them lol
Ok maybe I can take it off clean it sand , prime and repaint it. ThanksIts plastic, had mine off before. When its on the truck it feels very solid because of all the attachment points
