What early 5th Gen issues are still affecting the 2023 models?
DanAR
Arkansas
I’m a new Ram Limited owner. After perusing old threads and often reported issues with the 2019 5th Gen, which ones seem to still be plaguing the 2023s? My truck was assembled 6/30/23 so it’s a somewhat late 23. Here are some I recall seeing repeatedly from browsing. I’m sure I’m missing some, especially in the media/electronics and possibly mechanical areas.
Leaking rear bed light or third brake light
Leaking rear opening window (read something about a different supplier or change maybe)
The Hemi tic - lifter/cam
Delaminating leather dash surfaces
Broken visors
Exhaust manifold leaks, cracks, warped
Have some of these (hoping most) been dealt with and corrected or improved by Stellantis by mid-2023? You would think after 4 or 5 years most would have been addressed with suppliers or assembly process revisions. Maybe only to be replaced by new ones. I hope most of the leak ones have been addressed - I would hate to have to check out the rear seat area for water every time the truck gets wet.
Thanks
I'm lucky to have experienced none of those issues (yet) with my 2019 (built July 2018).
My RamBox lids are also pretty well aligned (not perfect), but I know that's been a common complaint.
We've all experienced some quirks with UConnect (both 4 and 5), so I'm not sure you can consider that 'fixed'.
The only nagging issue I've had is some squeal under light braking (45-25 mph, or thereabouts) when hot. I've had the relevant TSB performed, but it did nothing for them. So far, I've just turned up the radio and ignored it.
Broken visors
Thanks
Third brake light, and rear window have been redesigned. The rest haven't changed, they may or may not happen.
That’s at least comforting on the leaks. Nothing worse than getting in your truck a few days after a rain, and the interior smells like a wet dog.
The redesigned third brake light has a marine style closed cell gasket, what it should have been from the beginning.
What about the rear window surround cracks? Do those still happen on 22 or 23 models? Is that perhaps redesigned too?
Something you read a lot about too.
I actually think there were 2 redesigns. First still leaked. I heard there was just a new design in June.
