Hood Alignment
Stephen1767
Hey everyone i have a 2022 bighorn 1500 and the gap in the hood is a slight bit larger on the right side not a huge deal but i am ocd and it bugs me has anyone else experienced this and if so how can i correct it thanks
Loosen the bolts, realign, tighten the bolts, done.
Loosen these two bolts and tap on the hinge with a rubber mallet. The hinge doesn't have much range, but it will drop about 1/4". You might have to lower the hood to the almost closed position and pull it forward a bit.
Before on the bottom. It's not perfect, but it matches the right side.
Awesome thanks!
