How tall can i go?
DeanM2
Have a new 2023 Big Horn with factory 18 Inch wheels, and 2 inch level lift on front. Minimal off roading. Can i put 34 inch tall tires on without issue?
Thank you.
On stock rims 34's will be fine but close to the uca's making it difficult to air down. 35's will likely rub and you won't be able to air down..
Thank you.
Why would airing down result in being closer to the upper control arms?
Depends on the tire width. You may need wheel spacers
