That's why the engineers use fuel flow rate.The only way to know actual mileage, is to hand calculate, over multiple tank fulls. Even hand calculating each tank isn't totally accurate, because each fill isn't exactly the same.
Sounds about right.On a recent trip I filled up and went 84 miles at 70 mph got to my destination and filled up again 3.3 gal truck computer says I was doing 23.2 avg and was reset at beginning of trip with the 3.3 gal at 84 miles is 25 mpg I have the 22 Quad with 3.21 and 5.7 Hemi so as far as hand calc Id say thats pretty good
but according to the actual gas I used its more like 25mpg how is that possible at 70 mph all hwy btw no city streets less than 1 mileSounds about right.
With 3.21 gears you should be able to do 23 easily on the highway at faster speeds than my 3.92's. I always have the windows up for best aerodynamic performance, and cruise set around 68 for my 3.92 gears. With 3.21 you can probably cruise around 78 (?) and still be under 2,000 rpm? Aerodynamic drag isn't quite linear, but it's close so going faster means proportionately a little more resistance, not logarithmically a lot more. The difference between 68 and 78 isn't a lot so as long as you keep it under 2k rpm you should get decent mileage.
In most of Canada and around here max speed limit on most freeways is 62 mph. New Brunswick and the Coquihalla in BC have 68 and 74 limits respectively but they're limited in scope. Most open highways are 50 mph. Anecdotal info - in Canada most people don't use the term freeway (like the 401 in Ontario), they're generally all referred to as highways.
I recently started using Fuelly to track my mileage. 80% of my miles are interstate driving at 80-82 mph turning 1900 rpm with 3.21’s on mostly flat terrain.Sounds about right.
Hand calculating has some variables. Such as in the USA it's gallons which are 3.8x larger than CDN liters which adds a bit more variance in your numbers - the more decimal points or smaller values you have, the more accurate the calculations. I wouldn't worry about it unless the numbers are way off like 2-3 mpg or so. If I was getting 28 mpg, I'd be wondering what's going on, just as much if I was getting 15 mpg.but according to the actual gas I used its more like 25mpg how is that possible at 70 mph all hwy btw no city streets less than 1 mile
Mine is pretty close to hand calculated. All I know is I've done the math to confirm it's right, and my truck is getting slightly better than RAM/EPA estimates so I'm happy.My dash mpg readout is consistently 1 to 1.5 mpg higher than the calculated mpg on Fuelly. Hand calculated is exactly the same. Don’t believe what the dash readout tells you. Ram is trying to make you feel like your doing much better than you actually are.
Well, a 40 mile trip netting 23.5 mpg might make you feel warm and fuzzy, but realistically, just like you said, actual mpg is average over multiple tanks, and hundreds of miles, not just a 40 mile trip, but hey, it looked good in that 40 mile trip!The only way to know actual mileage, is to hand calculate, over multiple tank fulls. Even hand calculating each tank isn't totally accurate, because each fill isn't exactly the same.
WOW! All 35 miles! Did you get that warm and fuzzy feeling last year?View attachment 166858
I got 38.5 on this trip. Most of it was downhill.
This. I bought a truck, not a Prius.Last time I hand calculated it was really close to the dash. I can’t remember now as I don’t care about the fuel mileage anymore.
NopeWOW! All 35 miles! Did you get that warm and fuzzy feeling last year?
I guess you and some of the others here don't get the point of "highway" mileage. The EPA and RAM state city, highway, and combined mileage as separate ratings.Well, a 40 mile trip netting 23.5 mpg might make you feel warm and fuzzy, but realistically, just like you said, actual mpg is average over multiple tanks, and hundreds of miles, not just a 40 mile trip, but hey, it looked good in that 40 mile trip!
Combined mileage is not the same as average mileage.I guess you and some of the others here don't get the point of "highway" mileage. The EPA and RAM state city, highway, and combined mileage as separate ratings.
I did a separate highway run to prove a point - I can get 23 on the highway with 3.92's. This is not an average rating. The proof is right there. It was actually better than their ratings and better than I expected from the truck. I don't feel warm and fuzzy about it - it's a fact, not a fuzzy feeling. Although I like warm and fuzzy feelings from time to time, especially with whisky. LOL
What I get in the city or combined is not 23 and that's not what I'm talking about here. But I expected that and I'm ok with that too. But when people say I can't get 23 on the highway, I don't really care, whatever. I just move on and have another whisky...and enjoy my 23+ mpg on the highway...not at the same time though... LOL
LOLCombined mileage is not the same as average mileage.
Wait...my truck isn't a Prius?This. I bought a truck, not a Prius.
DANG....maybe I should buy a Chevy....do you have a business card so you can get a commission?My Silverado got 30 mpg
It identifies as one. Just doesn't get the same fuel mileageWait...my truck isn't a Prius?
OK...who do I talk to about this fiasco?
