Anyone running 295/60-20s with leveling kit?
Gonna be pulling the trigger on new tires after I get back from Xmas and I wanted to know if anyone was running those with just a leveling kit? I am torn between those and the 305/55-20s. Gonna be going Ridge Grappler FWIW. Thanks.
-Greg
I just picked up my truck this week and had a 2" Ready Lift Level installed. Running 295/60 R20 with +1 offset. No rubbing
I’m running Nitto Ridges 295/60 as well. No rubbing, fills the wheel wells nicely
-Greg
I ran 305/55/20 ridge grapplers with 2 inch level on my 14 ecodiesel and it was the perfect stance.
I put Nitto G2 305/55/20 on stock sport wheels . They actually fit with no lift but the problem was the space between the control arm and tire . There is only 1/8 to 1/4 inch clearance when suspension is loaded. The Gen 5 has a narrower track or wider body than my 2016 gen 4. Tires in front are 1 1/2 inch inside wheel well and rear is 1' inside wheel well . There is a 1/2 " difference front to back. On the Gen 4 they were perfect. Gen 5 needs spacers to get the same look.
I have the 2.5 Motofab with 20x10 -18 wheels. I got the Ridge Grapplers 295/60 put on today, and they rubbed my Husky mud flaps. Took them off and everything was perfect. Tires look great, too.
Anyone have any pics with their 295 60s?
Here ya go
I have 295/60-20 Falken Wildpeak tires mounted on some factory Laramie wheels for my truck. Just installed Readylift leveling kit and upper arms on my ORP truck yesterday. Tires/wheels are going on as soon as the alignment is done (Monday or Wednesday). I'll get some pics when it happens.
Cummins2hemi - do you have any pics you can post? Looking at the same tires for a Limited and trying to determine if I need the xtra height of the ORG to fit the 295s.. What are the specs of your truck? Offset of your wheels?
Looks good bud! I have a Laramie sport with the ORP and ordered the readylift UCAs and a 2.5” motofab spacer. Looking at your truck yours looks perfectly level, in some other posts with ORP truck the 2” still looked low in the front. Hopefully mine won’t be looking like a rocket ship and be high in the front lol. I went with the 35x12.5x22 fury MTs on a 22x9 wheel. It’ll probably be a few weeks before I get everything on but will try to remember to come back and add some pictures.
Thanks guys! I know it looks level, but it does have almost a solid inch of rake still. I really like the stance. I did machine some 1/4" spacers and added them to the Readylift spacers. I did the math and the 1/4" spacers add just shy 1/2" of lift. So it's basically got 2.5" level kit.
Oh okay then I feel a lot better about the 2.5” spacer I have ordered haha. Looks great man. Hopefully mine is put together by the end of the month.
Aren't you going to have major rubbing issues? What offset are you going to do?
I got it done yesterday. Haven’t found any rubbing yet. Did a 22x9 +31 offset and 35x12.5x22 MTs
