Radio works but no sound
rormiester
So discovered the F12 fuse for the Audio Amplifier Module / Active Noise Cancellation (ANC) / Sine Wave (SW) Inverter was blown. Tried to put a new one in and it immediately blew. Disconnected the amplifier under the seat, put in a new fuse and didn't pop. Plugged the amp back in and it blew again. Leaves me thinking I need new amplifier? Any tests I can do on the amplifier while I have it out?
I’d be checking the wiring to the amplifier. If it’s got a spot that has rubbed through the insulation (and grounding out), it’ll blow the fuse. I would consider that a much more likely scenario than needing to replace the amp.
