Largest tire for stock 2WD 2023
TWLRSC
Forgive me if this has been asked before. Anyone know the tallest and widest tire I can install on Stock 2023 2WD BIG HORN 2WD. No level with stock 20" wheels. TIA !!!!
What look are you after?
This will change slightly with width but look for a tire with an overall height of 32" to 33" at the max.
I have the Michelin LTX 305/45R22's on my 2019 and they are listed at 32.8" overall diameter. They make contact with the liner at full clock but it's very minimal. The tread width on them is 10.3" so a narrower tire could be even taller. I'm not sure what the 20" equivalent would be but I think you could still go up one size from what I'm running and still not have any issues worth worring about.
Search 305/50R20.
Search 305/50R20.
The 305/50r20 is EXACTLY what i was wanting to put on ! Just not sure that would rub. Thanks !!
It's actually slighter smaller in both diameter and width so it likely won't rub at all and sill look very good.
