Bacoviah
- Jun 10, 2018
So over the past weekend we did a total system upgrade and swap. The new system consists of:
Maestro dsr1
Focal Flax 3way
Us Acoustics “Mike” sub amp
JL Audio vxi 800/8 for the 3way
2-jl audio 13tw5(box will be ready tomorrow)
JL Audio 12tw3 in prefab(loaner until box is ready)
Background:
After many years of being a novice and competing is IASCA and modifying many vehicles I decided to keep this vehicle stealth or a stock look. No visible fabrication. Well except for the sub box.
Details:
We put the focal tweeters in the upper door stock speaker location.
Midrange in the stock dash corner locations.
Midbass in the lower door location.
This isn’t ideal for proper imaging but again I did not want to cut into the inner door panel to make the midrange fit in the door upper stock location. More on this later.
I’m having a box made for 2-13tw5 subs but the shop had a bit failure at the last second. They did give me a loaner sub in a prefab box from JL. This was a priceless gesture on their part. Kudos.
The maestro dsr1 we installed where the factory amp was since this equipment allows me to delete the factory amp/anc.
Side note on this. The resistors that come with the maestro make sure you solder instead of using the clips. This will help prevemt introducing noise in to the system. Thank you Michael Cook!!! For this tip.
We are using the dsr1 with all channels full range to flatten the factory signal and using the on board dsp with the JL vxi 800/8 for processing and crossovers.
I am able to eq individual channels on the vxi and then able to use the dsr1 as a master eq with the channels linked to help prevent phase issues. Using both also provides a powerful processing tool.
Forgot to add there is zero noise in the system. A complete black hole!!
The amps we installed behind the rear seat since we removed the factory subwoofer. We also opted to use the factory panel to hide the amps instead making a visible amp rack. As it turns out where the factory sub was there are slits in the carpet that now let fresh air behind the factory panel. I’ll be reproducing this slots for the other amp.
How does it sound??
Ok...so this is where it gets interesting. I’ve owned many vehicles with systems but this is easily the best system I have ever had. The imaging and full sound with the midrange firing off the glass is phenomenal. Huge wide soundstage with plenty of depth and clarity. The only drawback I have is the tweet in the upper door. With this location it brings the soundstage down on the sides which is causing a “rainbow”. Not bad but is audible.
If you have any questions let me know.
Maestro dsr1
Focal Flax 3way
Background:
Details:
How does it sound??
