Leaking back window 2019 Ram 1500
Synginman
Does anyone know what the new part # is supposed to be for the rear back sliding glass window.Also does this fix the problem.
You didn't say what year your truck is. Mine is a 2019 new addition and had the dreaded cracked rear window frame. The Star Case Number was S20223000005 Rev A with a release date of 11/26/2020. This case number showed the correct Backlite part # as 68426398AD. If your truck is newer it might have a different part number. This was/is a common problem and a search of this forum should find what you need. Also a call to your local dealer should give you the correct number.
Sorry it is a 2019 Ram 1500 new body style.I already had the back window replaced not long after I bought it.Now the window is cracked again and leaking.Iam in the process of getting another new replacement window.Iam hoping this is a newer model and that they have fixed the problem.That is why I was wondering what the new part# was so I can try to make sure I get the newer one not an older version.
