KIBarrister
- Mar 13, 2021
If my review of search results is accurate, this may be a can of worms, but I was looking at swapping the diff cover when I upgrade to a Hellwig sway bar. I have no idea if Banks is credible, but I saw a few posts indicated [essentially] it doesn't matter because he doesn't make one for Ram. In my searching (because I hate my day job), I ran across:
bankspower.com
I think that is saying it would fit the 5th gen ram rear end. I have a 2021 Laramie 4x4 w 3.92 gears. I do a fair bit of towing and at 60k miles, I think it would be wise to pull the cover and clean the magnet, as opposed to a simple drain and fill. I'll be down in the dunes of OBX for ten days later this summer and want to make sure I have everything squared away before then (the cost for a tow off the beach is damn near piracy), and I'd rather not put that abuse on my diffs with worn gear oil...
Ram-Air® Differential Cover Kit for 2019-2026 Ram and 2020-2026 Chevy/GMC, with 11.5" or 12" 14-Bolt AAM Rear Axle [19288] - Natural Aluminum - Banks Power
Banks Ram-Air Differential Cover rejects heat 5X quicker than stock. 2X more surface area. Extends oil life and mpg. For GM/RAM 11.5/12-inch 14 Bolt axle.
bankspower.com
