Should have configured the 3.92. Can I upgrade after purchase?
irishwake63
If it was a tow behind yes it would be but these are 5th wheel Made for 1500’s. Winnebago uses hitch weight which might be a little confusing.
Not sure what you mean most 1500s can tow any of these 3 well within specs
You realize this thread, and comment you are replying to are over three years old right? And the person you are replying to hasn't even been on the forum since Aug of 2021.
irishwake63
Actually no but its still here so I replied to it what difference does it make its a forum
irishwake63
is there any way to find out what rear diff ratio you have other than the window sticker?
Scram1500
Look at your RPMs on the highway. In 8th gear 3.92's with OEM 32 inch tires it will be around 1900-2000 rpm at 70 mph.
Look at your RPMs on the highway. In 8th gear 3.92's will be around 1900-2000 rpm at 70 mph
Depends on your tires. With my 3.92 and 35" tires my RPM is around 2000 at 75mph
Haven't looked in mine, but they used to have a sticker in glove box with that information on it
