Tailgate hard to lift
Shumax2
Recently I have noticed the tailgate is harder to lift. It has a gas assist shock behind the taillight.
Has anyone replaced this shock?
The "shock" is a damper to resist fast movement. I don't think it does any "assist". You may be developing rust in the hinges. Or maybe you made the tailgate heavier by adding a liner, rug, light bar? Or maybe it's just life, I've noticed my basement stairs are a lot steeper than they used to be. ;)
You are the first one that I have seen reporting this with a failing gas strut.
Most likely/hoping for it to be a generic strut available online.
Alldata shows it as an item #3 but no P/N.
Not sure how RAM does it but Ford has a long rod inside the tailgate (it is basically the length of the tailgate) that is getting twisted when you open it and untwists itself when you close (which is what provides the lift assistance - it's not the gas shock which acts just as a damper, it actually would provide resistance when being closed) - it is basically a torsional spring.
Typical failure mode there is the block holding the end of this rod failing and not holding it. Could be the same case here and it is major pain in the *** to fix (ask me how I know....)
It also assists in lifting/closing
