No pictures yet, I am in the middle of the install. When I purchased the sub from Crutchfield I asked if I needed any adapters for my application. They replied no, everything I needed was in the box. I started by mounted the sub under the passenger front seat, it barely fit and just clears the seat adjustment lever bar. Next, I wanted to run the power supply wire through the passenger side firewall but no where I could find a easily accessible hole and I did not want to drill one. So, I ran it under the dash to the drivers side and came through the main harness grommet, there was a plugged hole below the harness that I used. I grounded to the rear seat mounting bolt. Next step is where I am on hold, the speaker signal input. I contacted Crutchfield through the chat and asked what my options were to tap into the speaker wires. I was told the norm, rear of radio, front or rear speakers. I asked about under the drivers seat. The sent an image of the active noise cancellation module. I said that is what it looks like under my seat. They replied your in luck, we have an adapter, iDatalink bCH3, we offer to make the speaker connections a breeze. I replied that I asked about any adapters I would need for my application when I purchased it, they said no. They apologized and are sending me the adapter free of charge, I will receive the adapter tomorrow, install will continue...........
