Unknown Connector
RamReb2021
Fort Worth, TX
Anyone have an idea what this connector is for? It’s behind the left rear seat of a 2021 Rebel. It comes out of the harness at the bottom and not the black module on the left.
Most likely etorque battery connector.
Sent from my LM-G820 using Tapatalk
Long overdue but thank you for your responses. I never found out what it was but I just zip tied it out of the way and mounted my radios.69110283404__83C3803B-5D23-414C-951E-A56DB9507127.jpeg
Long overdue but thank you for your responses. I never found out what it was but I just zip tied it out of the way and mounted my radios.View attachment 159514
What are these radios for?
While you are there, I would HIGHLY recommend putting silicone around those sunroof drain grommets to make sure water doesnt leak between the grommet and the body panel. I had a huge leak from those, even though they were installed properly as yours appear to be.
I just double checked the pics from when I had mine that far apart and I don't have a connector like that on my '19 rebel
Ham radio. The one on the left is a VHF/UHF radio. The radio on the right is an HF radio. The silver box is an antenna tuner for the HF radio.
I've been back there many times and haven't seen any leaks... yet. Hopefully it stays that way. Thanks for the tip though.
It is a bit of a hassle getting back there. I just bought some Milwaukee battery powered ratchets. Makes the job so much easier.
