Yes, I haul plywood once and awhile, so I built that ledge at the rear window side to rest the plywood on, then that bar on top removes and slides on the 2 nubs sticking out off the back legs, pin it in, I can put 25 sheets across without having to empty the bed out.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
