colet123
- May 9, 2023
Hey,
I noticed the drivers side LED tailight (exterior led strip always illuminated at night) decided to stop working. All other functions (brake turn reverse) work on the drivers side but not the tailight portion.
First thing I checked was the fuse for it under the hood and it was blown, replaced it, did not fix. Brought it to the dealer I purchased it from (bought used from a GM dealer, had an extended warranty) they could not figure it out, advised they "could not find an issue with the wiring." Considering new OEM tailights w/ the blindspot monitoring were $1600+ CAD, I bought a used one off of ebay for just under $500 (my extended warranty would not cover this). Popped it in crossed my fingers and guess what! Still does not work... Even tried checking for code to see if any were related to the tailight to no avail.
Only guesses at this point are there are additional fuses that interact with the tailight that im missing, or it is indeed a wiring issue that the dealership did not catch. Im pretty certain it is not an issue with the tailight itself given that I replaced it with another and it did not fix my issue.
Any reccomendation or anyone else had a similar problem. Any help would be much appreciated!
