ImEngineer
- Nov 22, 2022
2019 Rebel with the 5.7, I purchased the tuck in November 2022. I missed one gas receipt when I let my sister borrow the truck.
I do the same but for a totally different reason:So all this tells me that you are one of those guys that when that nozzle clicks off, you are content to just immediately hang up the nozzle and leave the random value in cents. When I pull into a station and see it on the screen from the previous person, I've always wondered about your kind. Me personally, my OCD will not allow me to simply leave it there...I gotta round that up to at least the quarter (.25, .50, .75).
I can appreciate the spreadsheet though...that's more my language! I also can feel your anger towards your sister for forever leaving a hole in the spreadsheet that can never be fixed, some people just don't understand.
Have a great day you elusive Yeti!![]()
Mine is about the same. I live in Denver, for what it's worth. The fill-ups on 2/17 and 2/19 were on I-70 driving across Kansas at approximately 75-80mph.Except for that staggeringly Prius like 15 mpg you started off with, that looks about the same as me, especially your more recent mpg figures.
What's your drive cycle like? Mine is about 70% city/ 30% highway on generally hilly type roads with lots of elevation changes.
Haha, thanks. You're spot on. I'm a former mechanic and have seen many vehicles have their emission system (particularly the fuel vapor handling system) damaged by topping off a tank, so I avoid doing that. I'm not sure whether that is a common problem on these rams, but I don't really want to find out.So all this tells me that you are one of those guys that when that nozzle clicks off, you are content to just immediately hang up the nozzle and leave the random value in cents. When I pull into a station and see it on the screen from the previous person, I've always wondered about your kind. Me personally, my OCD will not allow me to simply leave it there...I gotta round that up to at least the quarter (.25, .50, .75).
I learned that the hard way TWICE when I drove Silverado’s and it was costly to fix. I’m a slow learner. Now it clicks and I’m done. Haven’t had issues since on any vehicle.Haha, thanks. You're spot on. I'm a former mechanic and have seen many vehicles have their emission system (particularly the fuel vapor handling system) damaged by topping off a tank, so I avoid doing that. I'm not sure whether that is a common problem on these rams, but I don't really want to find out.
Bingo!Haha, thanks. You're spot on. I'm a former mechanic and have seen many vehicles have their emission system (particularly the fuel vapor handling system) damaged by topping off a tank, so I avoid doing that. I'm not sure whether that is a common problem on these rams, but I don't really want to find out.
Damn, I thought mine was bad @ high 15's lifetime. (Fuelly link in the sig)
Yep. Rebels are not built for mileage.It's mostly a Rebel thing.
"But my sticker shows between 15-21 mpg....why is it so low".
Folks don't understand that the fuel economy sticker is usually with a lower trim, in perfect conditions ( not alot of stop and go, and humidity weather doesn't change), and whine about MPG.
Very interesting number. I don't don't do alot of hyway travel and alot of just side streets with stop and go traffic. My MPG number is always around 10 mpg.
Once I hit the hyway, it climbs to 15-19 mpg...with mds off. Then when I turn on mds, it's higher.
2016 Dodge Charger scat pack
It's a big time shocker for some. Definitely not for me. I agreeThe window sticker mpg is based on a RAM 1500 with a 3.21 rear axle on 18" street tires, that's what the EPA tested. RAM then blanket stated all the window stickers for all the various trims regardless of axle ratio or tire size & type.
The EPA allows this, it's not illegal, but they do allow the manufacturer to adjust the mpg figures down on certain trims if they want. RAM clearly decided against this, which is a bit shady on their part. Chevrolet did the right thing and actually lowered the EPA figures on their Trail Boss trim trucks because they knew the 32" Duratracs were going to hurt mpg.
For me, as someone who has owned trucks with bigger tires, I knew there was no way that a 3.92 axle 33" A/T truck was going to get anywhere near that window sticker. But for people who are new to it, it probably has been rather shocking.
