Center console
HYLTONzero
Does anyone know if you can swap the outer cover of the center console? I have a gray console and someone has a rebel console with red trim but it has the Rear USB ports. Can the internal pieces be swapped or can I take off the red trim external cover and replace it with my gray cover.
I don't know what trim you are talking, but this may answer your question.
The TRIM components can likly be swapped, but the textured plastic side panels with map pockets cannot be swapped as they are welded to the structural center console.
Thank you. Someone is selling a rebel one with the rear USB ports but it’s red trim. If I can replace all the red trim with my trim then I win. Thanks for sending this.
