brian42
It's the same as those of us "common folk" without the eTorque.
Long gone are the days where you had to write down all your settings and presets before disconnecting your battery. As mikeru82 said, it seems to be almost all EEPROM nowadays instead of volatile memory (RAM...no pun intended
When I disconnected my battery I don't think I had to re-do any settings. Coming from a 2003 Ford F-250 I was ready for everything to be "factory reset".
I was having problems and the dealership told me to disconnect the batter for 30 minutes or so and see if that helps. Seemed logical as that's what I've been used to doing for the last 35 years. It did not fix the problem so I took it in for the dealership to look at it. When I dropped it off I told them that disconnecting the battery didn't fix the problem and I was told to never disconnect the battery as it could cause problems in these newer vehicles. Somebody needs to train their maintenance staff so they have the same answer...
