Upgraded suspension without lift?
Durangoram
I have a 2022 ram 2500 without airbags. I want to upgrade the ride quality without lifting the truck at all. Would coilovers be best. Or new shocks and add airbags? Any suggestion in option without lifting?
Wikielliot
I did Bilsteins 5100 all around with Core 4x4 rear upper, lower control arms, panhard bar and sway bar end links, Hellwig rear sway bar, Suspension Maxx front sway bar end links and JBA off-road front upper control arms, it honestly rides like a cloud.
Sent from my SM-S918U using Tapatalk
Durangoram
What
Do you think the 5100 alone would make a big difference. Or are all the mods you did needed to get the ride right.
Wikielliot
The first thing I did was the Bilsteins and that by itself is a big difference
MikeyHo808
Hawaii
Yeah, a 2500 is a pretty different animal than us 1/2 tons. You may wanna mosey on over to the HD forums for more info. Good luck👍
H2OMAN
The O.C.
You can't do coil overs on a 2500. Still, all the big manufacturers will have you covered with suspension. You don't have to lift.
