Anti-Spin Differential Rear Axle
palumaa
Hello!
I couldn't find information about this quickly.
What are the options for installing an "Anti-Spin Differential Rear Axle" on a 2022 RAM 1500 Limited (Ecodiesel)?
Is such a product or similar even on the market, and has anyone maybe done it?
I would think there would be seeing how it was an option from the factory. I ordered my 2022 Bighorn with the anti-spin differential and 3.92 gears
Yeah, junkyard for an OEM, or possibly a lunchbox locker is available also.
I forget who, but someone does make one for the ZF 9.25 rear. The one from the factory has no preload spring and I believe the aftermarket one does.
Option 1 is incorrect. You can install the factory anti spin diff quite easily, OR you can install the factory electronic locker and the required dash switch and option enabled in the computer.
Or the aftermarket as was said.
