Diablo Intune i3 issues
deepc6
Hello,
A couple of weeks ago I tried to install my unlocked PCM with the bypass on my 2020 1500. After the initial startup I was missing a lot of functions:
Brake Controller
Reverse Camera
360 Camera
Navigation
XM Radio
Passenger and rear seats cooling and heating
Drivers side cooling seats
HVAC temp would only go from min to max.
Some other functions I am sure I missed.
Has anyone else experienced functions and features not working?
Mopar_maxi
If you disconnected the battery during the pcm swap, as you should have, once reconnected, all of your functions will come back in a short timeframe.
Darksteel165
Massachusetts
I second what Mopar_maxi said.
Disconnecting the battery can cause lots of weird stuff for 24 hours.
Also it's possible you applied an incorrect tune, and you would want to revert to stock and reflash it.
deepc6
I disconnected the battery during the swap, I will try it again.
Thank you!
rvnweems
Hello,
Brake Controller
Reverse Camera
360 Camera
Navigation
XM Radio
I just had my starter replaced (this morning) on my 2018 Charger, and my reverse camera, passenger seats cooling and heating, lights (modifications) , rear defroster (on screen) and probably some more things are missing. Did your issue ever correct itself ??
deepc6
Hello,
It did, it took 1-2 days for the problem to be corrected.
