Tints, Ultra Vision Stealth Windshield Tint, Borla Atak Exhaust, and RamAir Intake. I tried to upload a video but I don’t know how.
You'd have to upload to YouTube,.or some other video sharing sites, and then post the link
Darksteel165
Massachusetts
Removed a rats nest from my snowblower and replaced a chewed fuel line....
And installed my pod light in my trailer hitch with a splitter cable for my 7 pin.
Running light
Brakes on
Reverse lights
I didn't realize my camera was changing exposure until after I came inside so it's hard to see how much more light it throws (a lot)
Without pod
With pod
Idahoktm
North Idaho
Running light
Brakes on
Reverse lights
Without pod
With pod
Do you have a link for the pod light and a daytime pic of it installed in the hitch? Is it so bright that it will pi$$ off people in the parking lot behind you?
Darksteel165
Massachusetts
Whops forgot to include a link it's the CR1
HitchMount LED Pod Reverse Kit
Realtruck via the forums can likely get you a better price. I paid $130 for mine.
I don't have any daylight pictures as I didn't put it on till around 5pm I can take 1 tomorrow.
It's only bright in reverse, which at that points it's suppose to be bright. The brake light is bright, but pretty close to the rest of the lights. The camera makes it seem blinding, which all of the lights are the 10 feet away I was.
Mopar_maxi
Went to the track yesterday to get some data. I ran the truck full weight on my heavy 20x12 wheels. I wasn’t sure how well I would hook up being on street tires. Lowered rear tire pressure to 22psi and eased into the throttle. Overall not bad, a lot more potential. Worked some bugs out and got some good tuning data for my tuner.
6of36
Michigan
No internals? Just the bolt on headers, throttle body, intake, and balancer, with a tune? That's amazing with an almost 6,000 lb vehicle.
Darksteel165
Massachusetts
Day pics
Metal housing with plastic push clips on the side (you can cut and use a locking pin).
I think it would stay in even without the push clips, it's a tight fit so no jiggle.
2023-03-05 11.43.05.jpg 2023-03-05 11.43.12.jpg 2023-03-05 11.45.02.jpg 2023-03-05 11.43.24.jpg 2023-03-05 11.44.21.jpg 2023-03-05 11.44.25.jpg 2023-03-05 11.44.30.jpg
Idahoktm
North Idaho
Day pics
View attachment 153765 View attachment 153766 View attachment 153771 View attachment 153767 View attachment 153768 View attachment 153769 View attachment 153770
Thanks. I would definitely use a locking pin. I just want it to work as a reverse light, so I wonder if I can pull the yellow and blue wires out of the harness? I'll have to ask Diode Dynamics if that's possible.
Mopar_maxi
Completely stock unopened motor. Just standard bolt ons. Thank you! Definitely has more in it with a lighter wheel setup and more seat time.
Darksteel165
Massachusetts
You 100% can.
Just cut their existing plug wiring and use a curt adaptor, or tap into the exist wring.
Reverse has it's own wire, I believe it's white but you can just look at the diagram for the 7 pin on our trucks to confirm.
Idahoktm
North Idaho
You 100% can.
I was just going to pull the yellow and blue wires out of the back of their harness. Red is for reverse and black is the ground.
Eighty
Moderator / Dream Killer
Yes, that will work. I’d just make sure to seal up the holes if you’re yanking the wires out. Or you could cut/cap them, just in case you decide you want to use them later on.
I have the same lights (SSC1 Pro’s), but in a dual configuration at my tow hooks. No brake lights, just running lights and reverse.
Dschmid37
Lapeer, MI
Put on some of my decals today. Somehow misplaced my red "RAM" door decals, and I found a defect in my etorque emblem on the hood. The dealer is ordering me a new one and I'll make those red also. Added my AVS window vents, Husky mud flaps, and some red tow hooks.
Start Button- $15.39
Vinyl Lug Nut Covers - $26.99
Bed Side Hemi Graphic- $39.99
RAM Grill Emblem Decals- $15.00
RAM Tailgate Head Emblem Decals- $13.00
Ram tailgate “4x4” emblem Decal- $11.99
“Laramie” Tailgate Letter Decal- $17.42
RAM Door Emblem Decals- $15.00
Hood Emblem Decal- $12.00
Tow Hooks- $119.00 for the Red which turned out to be more of an orange color. Re-painted them myself to match my decals.
Weathertech FloorLiner HP floor mats - $124.95
AVS Window Visor/Rain Guards - $53.75
Xtang - Xceed hard tri-fold tonneau cover - $1,119.00
Bumper Plugs paint matched from Forum member Acogs91
familywagon
Did a real carbon fiber trim piece around the push button. Not sure how I feel about it. Fitment is ok.
Yes, it does, because it's for tail/markers and backups. Are your pods not setup that way?
My most light pods people are adding for supplemental reverse lights are only two wire white LEDs. The @VICE design adapter uses two pin connectors
