Anyone running a 295 60 r20. On a 20x10 ?
Mikey1641
Would like some advice.
I have the off-road package with the 2.5” MotoFab level. Yes I had some very minor rubbing on the back side of the tire. I used a heat gun to move the liner back, and the little plastic trim piece at the bottom of the liner. I was even able to modify my Husky mud flaps to get them to fit without rubbing.
This is the only pic I have on my phone atm.
Wow. Looks great. You think the 3.5 inch lift would be too much for that size wheel and tire ?
Not at all. It would raise the back end too, assuming your speaking of the Rough Country lift. Technically, I have 3.5 over stock in the front. So, that is a close comparison.
I’m sure you’ve read it in other posts, but if you do the 2.5 or larger you need to replace your upper control arms.
Yup. Thanks man. Can’t wait to get started. Will post pics.
Here are some more pics of your stance with those wheels and tires.
