Will the RAM AIRFLOW from Mopar fit the classic style engine bay
ordnance187th
Does anyone know if the RAM AIRFLOW from Mopar will fit the classic body style? I have a 2020 Warlock with the 5.7l.
Since it's the same engine, I'm sure the main part would. The only difference would be the radiator cover due to different front clip. Vararam fits in both 4th and 5th gens because you just trim your factory radiator cover.
mikeru82
The Palouse
You can probably modify things to make it fit, but since I don't have a Classic 1500 or a 4th gen I can't say exactly what you would need to do.
scottmoyer
I've seen the 4th gen setup fairly inexpensive on FB marketplace. You might have better fit going with the proper intake
