Have been meaning to pull back the carpet behind the back seats just to lay eyes on the battery pack and sub. Glad I did. A few observations:
1. The carpet "bridge" between the back of the rear console and the carpeted back wall is magnetic. You can just pull it straight off if you needed to get below it for any reason. I was getting a little annoyed at how that piece of plastic underneath the carpet was making an imprint on my rear console leather cover. You could just leave it down but then you'd have two holes and two magnets to look at.
Pulling up the back wall carpet is fairly easy:
2. I was a bit surprised to find a fair amount of road dirt all in the vents and into the cab. Those are supposed to be extraction vents (one way out of cab) and the flappers appear to be working fine. I'm wondering if it's due to being open so much because of the sub, i.e. we're not supposed to jam out on a dusty road?
3. Another poster mentioned that he found a loose item low center on the back wall. It's absolutely a source of rattling. It's one of the LF antennas and it looks like Ram has a batch of small plastic push rivets that are out of spec - too small. Found several on the back wall but this was the only item that is clearly banging on the metal wall. Stuck a piece of foam behind it and it's nice and snug now. It's the smaller item in the center that says LF antenna:
4. I also noticed that the back of the carpet wall from the drivers side to about where the battery (eTorque) starts, there is a vinyl layer on the back of the carpet, almost like some type of factory dynamat.
Also tried checking on my sunroof drain tubes from the inside. Driver's side looked perfect (was installed correctly from the factory) but the passenger side cannot be checked without removing the subwoofer. Maybe they are popping them out when they install the subs?
Anyway, all buttoned up and another rattle eliminated.
- Pull seats forward using string releases up near top.
- Pull two round and long center plastic push rivets out.
- Pull carpet from back - pull more in middle to allow some flex to pull out of side hard plastic molding. No need to remove molding.
- Unclip plastic housing around center seat belt. Unsnaps from driver's side with hinge on passenger's side and lifts off.
- You can remove the whole carpet if desired, but no need for this exercise.
- To reinstall, wedge sides back behind plastic molding and then push center to pop it all back, then reinstall all parts removed,
