285/60r20 on 20x9 +18 Turbomac HD
xNovax
I have some 20x9 +18 Turbomacs on the way and some BFG K02 285/60r20 in my garage. My trucks a Laramie with air suspension and I was wondering if this would fit. I haven’t been able to find anything about this specific size, I’ve seen lots of 275/60r20 but no 285.
I have 275/60s, which is a 33" tire and in entry/exit mode it may rub at full lock. I suspect you would experience the same being that those would be about 1/2" taller and 1/2" wider. Otherwise I have no issue at other settings.
I have 295/60/20 Toyo AT's which are a 33.9" tire and have only min rubbing of inner fender area at full lock at entry/exit mode. I could use a heat gun and bend the plastic back a bit, but just haven't gotten around to it. No level kit either.
Perfect so in normal mode I should be rub free.
Thank you so much!
Hey
Did you get these installed? I'm planning on these same tires on mine along with a 2" level kit (being done Sat).
Right on, looks awesome man. I can't wait till Saturday!
285/60r20 -19 offset no rubbing or trimming
