silver64
- Mar 5, 2019
Two days ago I went out to the driveway and touched the door handle to get in the truck. The auto lock sensor didn't pop the locks so I hit the unlock on the keyfob and it didn't work either. I went inside and got the other two fobs and the truck did not respond to either of them.
I used the physical key to open the door and of course the security alarm starts beeping. I closed the door and hit the start button. The center gauges lit up but the truck wont crank. Touched the key on the button and tried to start it that way. Nothing. Popped the hood and checked the battery voltage, its 12.8 volts so its good. I figured what the hell and hooked up the jump box. Nothing. It won't even go into accessory mode. It only stays in the off mode.
Called the local dealer & made an appointment for today and called a tow truck to take it in. When we tried to pull the manual release to put the truck in neutral for the tow it did not release the wheels. The electronic emergency brake would not release either. What a **** show. Hoping to find out what the hell went wrong with this thing later today.
