crusher
i think what im talking about is not called auto climate but more like auto on confort, there is no button for that its in the setting
When you use remote start, the HVAC controls will come in accordingly based on outside temp. Regardless of what you have set for auto controls in menu. That only controls the heated seat and steering wheel coming in.i think what im talking about is not called auto climate but more like auto on confort, there is no button for that its in the setting
i don’t ever utilize that button.But you did have the physical Auto button set on on the climate control dial ?
Than what do you expect ? Auto regulates fan speed to achieve faster heating / cooling of the cabin (assuming engine has enough heat in the case of heating). If it's off, it will just be at whatever (likely low) fan speed you set it to and of course won't be warm in the cabin in case of you remote start. Turn it on, it will do magic for you. Climate control in a car makes the most sense if you use that button.i don’t ever utilize that button.
That's not how the HVAC works when using remote start.Than what do you expect ? Auto regulates fan speed to achieve faster heating / cooling of the cabin (assuming engine has enough heat in the case of heating). If it's off, it will just be at whatever (likely low) fan speed you set it to and of course won't be warm in the cabin in case of you remote start. Turn it on, it will do magic for you. Climate control in a car makes the most sense if you use that button.
thank you for saying it.That's not how the HVAC works when using remote start.
Ok but the same principle may still applyi don’t ever utilize the “auto” button. i just adjust the climate control’s accordingly to whatever floats my boat during the time being.
You haven't driven it around Xmas last year when it was below freezing (have some friends in Houston) ?
Chilly... snicker..... snort..... chuckle.....as i said.. i’m from South Texas and 45 - 55 degrees is considered semi cold/chilly
It's not the auto button. It is a setting in your Uconnect radio. I don't believe these systems (defrost, heated seats, heated steering wheel) until the temp is below 40 degrees. 45-55 and your truck thinks it's warm and cozy out.i don’t ever utilize the “auto” button. i just adjust the climate control’s accordingly to whatever floats my boat during the time being.
maybe yours is broken? mine waits before its warm before blasting air,auto is useless, these trucks have the worst AC systems (maybe it improved in later years, but mine sucks!) 15 yr old toyota is smarter, auto will actually wait till the air in warm and control the volume and not blast cold air, or super hot air. I'm with you, not finding a need for auto.
Mine doesnt blast the air in "auto" until engine is up to temp in winter. Summer it kicks in with A/C quicklyauto is useless, these trucks have the worst AC systems (maybe it improved in later years, but mine sucks!) 15 yr old toyota is smarter, auto will actually wait till the air in warm and control the volume and not blast cold air, or super hot air. I'm with you, not finding a need for auto.
Last three RAM’s I have set my temp at 67 degrees and they have lived on Auto the entire time I owned them. Never found a need to mess with the climate controls all the time except maybe defrost once in awhile. Auto does what it needs to do for me summer or winter.auto is useless, these trucks have the worst AC systems (maybe it improved in later years, but mine sucks!) 15 yr old toyota is smarter, auto will actually wait till the air in warm and control the volume and not blast cold air, or super hot air. I'm with you, not finding a need for auto.
yes you’re correct on both statements.It is a setting in your Uconnect radio. I don't believe these systems (defrost, heated seats, heated steering wheel) until the temp is below 40 degrees.
i’m not following.. elaborate pleaseOk but the same principle may still apply
Same, but mine stays at 72 in winter and 68 in summer.Last three RAM’s I have set my temp at 67 degrees and they have lived on Auto the entire time I owned them. Never found a need to mess with the climate controls all the time except maybe defrost once in awhile. Auto does what it needs to do for me summer or winter.
i want to do the same but hate when the auto turns off my recirculation Lol. last thing i want is unwanted odors and or particles coming into my cabin.Last three RAM’s I have set my temp at 67 degrees and they have lived on Auto the entire time I owned them. Never found a need to mess with the climate controls all the time except maybe defrost once in awhile. Auto does what it needs to do for me summer or winter.
You have a cabin air filter. Get the charcoal type and it helps with odors. It's also not good to leave recirculation on the whole time. Especially in winteri want to do the same but hate when the auto turns off my recirculation Lol. last thing i want is unwanted odors and or particles coming into my cabin.
55 would be turn heat OFF!Well, when it actually gets cold out, try warming it up then and let us know how it goes.
55? Really? I'm hitting the AC button if the sun is shining through the windshield.
The other day the temps finally reached 40 and I had to fully open my pano sunroof to cool off.Well, when it actually gets cold out, try warming it up then and let us know how it goes.
