limechallenger
 - Dec 9, 2022
Mine leaks... does that count?!?!
Sent from my SM-G781U1 using Tapatalk
Sorry dude. So does everyone else's.Mine leaks... does that count?!?!
What brand did you use for the 1500 hemi 5.7 labels?Here are a few things I did to mine. The red lettering, IMO, is a little to red, but it can be changed. I've changed all of my speakers to Infinity's is the reason for the speaker grill badging. I tried to find the original Infinity badges from an early 2000s Dodge Ram door panel but there are none to be had.
Reflective Concepts is who I used. I've had them on there for two years with no problems so far.What brand did you use for the 1500 hemi 5.7 labels?
I am on my third set on vinal from reflectiveconcepts.
They always bubble a few months after installing and look terrible
+1 for reflective conceptsReflective Concepts is who I used. I've had them on there for two years with no problems so far.
What is your trick? My first batch bubbled inside after 2 months of being on. They sent me a replacement batch and those bubbled also.Reflective Concepts is who I used. I've had them on there for two years with no problems so far.
Like you said, I cleaned everything really well with rubbing alcohol and let it dry. On the 5.7L Hemi on the hood I used a tooth pick to help place and press the letters down to help them adhere better. After that I used a Q-Tip to press the letters down. I then waited about a week before I washed the truck.What is your trick? My first batch bubbled inside after 2 months of being on. They sent me a replacement batch and those bubbled also.
It was clean and I used alcohol to clean the surface before applying it each time. It also doesn't sit in the sun.
The ones for my rear taillights never bubbled (and those are in direct sunlight)
I did the same thing. So oddLike you said, I cleaned everything really well with rubbing alcohol and let it dry. On the 5.7L Hemi on the hood I used a tooth pick to help place and press the letters down to help them adhere better. After that I used a Q-Tip to press the letters down. I then waited about a week before I washed the truck.
Good luck with them if you try it again!
That is weird!I did the same thing. So odd
The company claimed gas was escaping from the plastic in my parts and there was nothing I could do except reapply themmaybe I'll try it again in the summer after my truck has its 1 year birthday
I put them on when it was like 75 degrees, back in the summer.That is weird!
One other thing I did was wait until my garage was around 70° before I put them on. Maybe temperature has something to do with it?
