Running board issues
jdwood165
I have a 2019 limited Dodge Ram 1500. I’m having multiple issues with the deployable running boards.
They started making a horrible sound when they moved. Like something was broken. Now they will deploy sometime and sometime they will stay out. While I drive every 2 min it makes a horrible sound. Like it is trying to deploy but can’t. And does it the whole time while driving.
Has anyone had issues like this? Any advice to fix it? Can I change a setting so they stay in place like pull a fuse so I can at least drive it?
Keep them stored on the touchscreen by going to: Safety/Driving Assistance > Power Sidestep > change from Auto to stored. Fyi if you ever disconnect the battery the settings return to Auto.
Most people seem to have similar issues. I try to keep mine clean and spray the hinges with WD40 but they're still useless in the winter.
I've never had a moment of trouble with them and we just went through the whole blizzard thing with subzero temps, and driving it a lot...no problems. OP, betting your problem is something simple like a piece of gravel or ice got lodged in the mechanism. Yes there is a fuse...it's in the fuse box in front of the engine compartment, but I don't recall which specific fuse. (easily searchable). You don't mention if this is happening on both sides or just one...again, betting its just one side.
Yes it is just one side.
Thank you. I was at least able to disable them and make it driveable.
