Best in channel vent visor? help?
Kaiser81
Looking to add some vent visors to the ram. What's everyone's opinion? Mopar? Weathertech? Other.? Looking at in channel ones.
I used Mopar in channel with no regrets. The only bad thing is they increase the blind spot at the A pillars.
I’ve used AVS in channel on every vehicle I’ve owned they work great and have a nice clean look.
I tried those on both of my rams and could never get them to fit properly. I always had a problem with the window going up. I wound up using the stick on's. I'd much prefer the in channel though lol
If you have a problem with the window getting stuck as it goes up. Take a close look at the visor. It will normally be the back rear corner.
It’s because the visors edge is molded with square edges/corners. Get a small file (jewelers file set works great) harbor freight. Leave the visor mounted in the channel, reach in with the file and slowly taper/bevel the corner/edge of the visor. It doesn’t take much. Raise and lower the window until it works as it should. That has always worked for me if I had a problem with the window going up.
I like the ones I have, but can find them anymore. The brand was US Visors and got them off Amazon.
I've had EGRs for 4 years and they still look like new. Made is USA and great customer service.
I have AVS. The Passenger front has a buckle in it and the Drivers side front I have to remount as it started to fall out.
I have to figure out how to get the VHB tape out of the channel first.
Malodave
I have the Mopars. They look and fit good, but I don't like how the metal clips rub the glass on the back.
I'll second the file. I always file the inside bottom edge of any in channel.
I've read about that. That's my only concern
I talked to several others who have had them for a long time with no issues, so I went ahead and left them on.
I almost removed them to just take my chances with the tape.
This is the one I have been using.
i bought these, worked great.just another brand option..your truck your money
