BiGJZ74
Does anyone make 2" Lift Rear springs for the 1500? I wouldn't mind removing the rear RL rear spring spacers for 2" Lift Springs.
Thanks I did see those, but was hoping for another option that wasn't Turquoise. Might have to if that's my only optionQuick google search shows it exists: https://www.americantrucks.com/dobinsons-ram1500-2-inch-rear-lift-coil-springs-110-lb-load-c16-051v.html
You can try this place. My plan is the variable rate spring because I pull a travel trailer and want a better ride when pulling.Does anyone make 2" Lift Rear springs for the 1500? I wouldn't mind removing the rear RL rear spring spacers for 2" Lift Springs.
www.tuftruck.com
